V5 Workcell Kit Storage - Bin 1: STEM Labs Hardware
This article will cover the pieces from the V5 Workcell Kit that will be organized into Storage Bin 1.
There are two components to organizing Storage Bin 1:
V5 Workcell Kit Storage Bin 1 Tray is viewed from above.
Tray
V5 Workcell Kit Storage Bin 1 Base is viewed from above.
Base
This article organizes each piece in Bin 1 and provides the following information in a table form from left to right:
  • Part: This is the name of the part. Hyperlinks are provided for replacement parts available to purchase individually at vexrobotics.com.
  • Photo: This is an image of the part. Use this for reference while unboxing your kit and building the V5 Workcell.
  • Part Number: If a part comes in a larger kit, bag, or box, the part number of the kit, bag, or box and the individual part number is provided. These part numbers can be useful when unboxing your kit and while building the V5 Workcell.
  • Quantity: This is the quantity of each part provided. Use this to ensure you have the correct number of parts in each location in the Bin or Tray while unboxing.
  • Bag Notes: This column provides information about how the part or parts in that kit, bag, or box will be received. If the parts come in a larger kit, bag, or box, an image of the label is provided for reference. Use these for reference when unboxing your kit.
  • Location: This is an image of the Bin or Tray with a highlight on where the part should be placed in that Bin or Tray. This information can also be useful while building the V5 Workcell if a reminder is needed for where a part is located.
    • Helpful Hints: These are provided in the Location column. These hints provide extra context or information on packaging, identifying part numbers, or tips for additional organization.
Storage Bin 1: Tray
Part Photo Part Number Quantity Bag Notes Location
#8-32 x 1/4" Star Drive Screw #8-32 x 1/4 inch Star Drive Screw. 276-4990-001 300 Comes in 3 bags of 100
Location of this piece is highlighted in the Tray's top right corner.
Helpful Hint:
Use the VEX V5 Metal Parts Ruler from rulers.vex.com  to easily distinguish and identify the different screw sizes.
#8-32 x 3/8" Star Drive Screw #8-32 x 3/8 inch Star Drive Screw. 276-4991-001 100 Comes in 1 bag of 100
Location of this piece is highlighted on the Tray's right side.
Helpful Hint:
#8-32 x 1/2" Star Drive Screw #8-32 x 1/2 inch Star Drive Screw. 276-4992-001 300 Comes in 3 bags of 100
Location of this piece is highlighted in the Tray's bottom right corner.
Helpful Hint:
#8-32 x 3/4" Star Drive Screw #8-32 x 3/4 inch Star Drive Screw. 276-4994-001 100 Comes in 1 bag of 100
Helpful Hint:
#8-32 x 1.000" Star Drive Screw #8-32 x 1 inch Star Drive Screw. 276-4996-001 100 Comes in 1 bag of 100
Location of this piece is highlighted in the Tray's bottom left corner.
Helpful Hint:
#8-32 Nylock Nut #8-32 Nylock Nut. 275-1027-001 400 Comes in 4 bags of 100 Location of this piece is highlighted on the bottom side of the Tray.
Helpful Hint: When dumping pieces into the tray, save the zip bags. These can be used later to organize parts that come in a variety bag.
Flat Bearing Flat Bearing. 100 Flat Bearings come in this bag:
276-6820-806
5 Flat Bearings come in this bag:
276-6009-808
Individual part number:
276-1209-001
105 Comes in 5 bags of 20.
The final 5 pieces come in this bag: Icon of a bag that contains three types of pieces including the Flat Bearings.
1/2" Standoff 1/2 inch Standoff. This part comes in the Standoff Bag:
276-7472-802
275-1014-001
40 These parts come in the Standoff Bag
Parts list of a bag that contains the seven different lengths of Standoffs.
Location of the Standoff pieces is highlighted in the very center of the Tray.
Helpful Hint: Use extra zip bags from unboxing along with tape and a marker to separate the standoffs out by size in individual baggies for easy access while building. Put the size of the standoffs and the individual part number on the outside of each bag.
Use the VEX V5 Metal Parts Ruler from rulers.vex.com  to easily distinguish and identify the different standoff sizes.
3/4" Standoff 3/4 inch Standoff. This part comes in the Standoff Bag:
276-7472-802
275-1015-001
4
1.00" Standoff 1 inch Standoff. This part comes in the Standoff Bag:
276-7472-802
275-1016-001
52
1.50" Standoff 1.5 inch Standoff. This part comes in the Standoff Bag:
276-7472-802
275-1017-001
2
2.00" Standoff 2 inch Standoff. This part comes in the Standoff Bag:
276-7472-802
275-1018-001
34
3.00" Standoff 3 inch Standoff. This part comes in the Standoff Bag:
276-7472-802
275-1020-001
28
6.00" Standoff 6 inch Standoff. This part comes in the Standoff Bag:
276-7472-802
275-1023-001
4
0.125” Spacer 0.125 inch Spacer. This part comes in a variety pack:
276-6340
276-5912-001
30 Comes in 3 variety packs
Icon of a VEX Variety Pack that contains Nylon Spacers.
Location of this piece is highlighted on the Tray's left side.
Helpful Hint: Use extra zip bags from unboxing along with tape and a marker to separate the spacers out by size in individual baggies for easy access while building. Put the size of the spacers and the individual part number on the outside of each bag.
Use the VEX V5 Metal Parts Ruler from rulers.vex.com to easily distinguish and identify the different spacer sizes.
0.25” Spacer 0.25 inch Spacer. This part comes in a variety pack:
276-6340
276-5913-001
30
0.375” Spacer 0.375 inch Spacer. This part comes in a variety pack:
276-6340
276-5914-001
30
0.50” Spacer 0.5 inch Spacer. This part comes in a variety pack:
276-6340
276-5915-001
30
1x1 Connector Pin 1x1 Connector Pin. This part comes in a pack:
276-7472-801
228-3616-060
4 Comes in 1 pack
Parts list of a bag that contains six different types of pieces includes the five listed here. The full list includes 1x1 Connector Pin, 2x3 Right Angle Beam, Double 2x Wide, 2x2 Corner Connector, Linear Slide, 1x3 Center Lock Beam, and Claw Gear Crank.
2x3 Right Angle Beam 2x3 Right Angle Beam. This part comes in a pack:
276-7472-801
228-3616-145
2
Double 2x Wide, 2x2 Corner Connector Double 2x Wide, 2x2 Corner Connector. This part comes in a pack:
276-7472-801
228-3201-220
1
Linear Slide Linear Slide. This part comes in a pack:
276-7472-801
228-3616-217
1
1x3 Center Lock Beam 1x3 Center Lock Beam. This part comes in a pack:
276-7472-801
228-3201-1141
2
Star Drive Shaft Collar Star Drive Shaft Collar. This part comes in bag:
276-6650-806
276-6103-000
96 Comes in 1 bag of 96 Location of this piece is highlighted in the Tray's top left corner.
1” or 2x Drive Shaft 1 inch or 2x Drive Shaft. This part comes in a variety pack:
228-6871-800
288-2500-117
20 Comes in 5 variety packs
Label on a Variety Pack of pieces called Foundation Add-on Kit Shafts.
Use the VEX V5 Metal Parts Ruler from rulers.vex.com to easily distinguish and identify the different shaft sizes.
2” or 4x Drive Shaft 2 inch or 4x Drive Shaft. This part comes in a variety pack:
228-6871-800
288-2500-120
30
3” or 6x Drive Shaft 3 inch or 6x Drive Shaft. This part comes in a variety pack:
228-6871-800
288-2500-122
20
4” or 8x Drive Shaft 4 inch or 8x Drive Shaft. This part comes in a variety pack:
228-6871-800
288-2500-124
10
Claw Gear Crank Claw Gear Crank. This part comes in a pack:
276-7472-801
276-6010-003
3 Comes in 1 variety pack
Parts list of a bag that contains six different types of pieces, including the Claw Gear Crank.
6T High Strength Sprocket
Note: This part is currently being transitioned from green to red.
6T High Strength Sprocket. Both the older green version and the new red version are shown. This part comes in a pack:
276-3876
276-2252-003
8 Comes in 1 pack
Label for the High Strength 6-Tooth Sprocket 8-Pack.
Gear Metal Insert Gear Metal Insert. This part comes in three packages
276-3880
276-3881
276-3876
276-2250-005
84 Comes in 4 of the High Strength 30-Tooth Sprocket packs.
Label for the High Strength 30-Tooth Sprocket 4-Pack.
Comes in the 1 pack of High Strength 6-Tooth Sprocket.
They will also come in two packs of the High Strength Shaft Insert Kit.
Label for the High Strength Shaft Insert Kit.
High Strength Gear Insert High Strength Gear Insert. This part comes in three packages:
276-3880
276-3881
276-3876
Individual part number: 276-2250-006
84
12T Gear HS Insert 12T Gear HS Insert. This part comes in a variety pack:
276-6009-808
276-2250-007
1 Comes in 1 bag of additional pieces
Label for a bag that contains three types of pieces, 12T Gear HS Insert, 12T Gear with 1/4 inch Bore, and Flat Bearing.
12T High Strength Gear w/ ¼” Bore 12T High Strength Gear with 1/4 inch Bore. This part comes in a variety pack:
276-6009-808
276-2250-008
1
12T Metal Gear 12T Metal Gear. 6010-011 12 Comes in 1 bag of 12 (labelled 276-7368) Location of this piece is highlighted in the Tray's top right corner.
Once all of the parts from the Workcell Kit have been placed into the tray of Storage Bin 1, the tray will look like this image (select the image to make it larger).
Top down diagram of the Storage Bin 1 Tray, with each section highlighted and its included parts listed. There are 13 total sections of the Tray.
Storage Bin 1: Base
15x30 Base Plate 15x30 Base Plate. 276-1341 3 These come in three boxes of two Base Plates.
You will need to open one of these boxes while organizing your storage bin to create two sets of three.
This piece is located in the Base of the Storage Bin.
Disk Feeder - Bottom Disk Feeder - Bottom. This part comes in this pack:
276-7720
276-7720-001
1 Comes in 1 bag
Label for a bag that contains the two Disk Feeder pieces.
Disk Feeder - Top Disk Feeder - Top. This part comes in this pack:
276-7720
276-7720-002
1
Arm Bar Arm Bar. This part comes in this pack:
276-7151
276-7151-500
2 Comes in 1 bag
Label for a bag that contains the Robot Arm Kit pieces.
Arm Bar 2 Arm Bar 2. This part comes in this pack:
276-7151
276-7151-501
1
Arm Transfer Plate Arm Transfer Plate. This part comes in this pack:
276-7151
276-7151-600
1
Arm Joint 3 Arm Joint 3. This part comes in this pack:
276-7151
276-7151-006
1
Arm Mastering Jig Arm Mastering Jig. This part comes in this pack:
276-7151
276-7151-011
1
Arm Joint 1 - Left Arm Joint 1 - Left. This part comes in this pack:
276-7151
276-7151-100
1
Arm Joint 1 - Right Arm Joint 1 - Right. This part comes in this pack:
276-7151
276-7151-200
1
Arm Joint 2 Arm Joint 2. This part comes in this pack:
276-7151
276-7151-300
1
Arm Joint 4 Arm Joint 4. This part comes in this pack:
276-7151
276-7151-400
1
Turntable Bearing Kit Large Turntable Bearing. This part comes in this pack:
276-5652
276-5652-000
1 Comes in 1 bag
Label for a bag that contains the Turntable Bearing Kit pieces.
Turntable Bearing Kit Small Turntable Bearing. This part comes in this pack:
276-5652
276-5652-004
1
Turntable Bearing Kit Turntable Mounting Bracket. This part comes in this pack:
276-5652
Individual part number: 276-5652-007
1
Dry Erase Surface Dry Erase Surface. 276-7157-006 1 This Dry Erase Surface can easily blend into the walls of the box because it is clear.
Make sure you keep an eye out for it on the sides of the box or along the very bottom.
Robot Brain Mount Assembly Robot Brain Mount Assembly. 276-7152-002 1 Comes in 1 bag of 1 This piece is located in the Base of the Storage Bin.
Input Output Conveyor Bracket Input Output Conveyor Bracket. 276-7153-001 8 Comes in 1 bag of 8 This piece is located in the Base of the Storage Bin.
Angle Couple Gusset Angle Couple Gusset. 276-2578-001 8 Comes in 1 bag of 8 This piece is located in the Base of the Storage Bin.
High Strength Conveyor Chain High Strength Conveyor Chain. 276-7141 6 chains Comes in multiple bags of 6 chains.
Only one bag is needed for Bin 1.
The other bags will be placed in Bin 3.
1x25 Steel Bar 1x25 Steel Bar. 275-1141-001 8 Comes in 1 bag of 8 This piece is located in the Base of the Storage Bin.
30T High Strength Sprocket
30T High Strength Sprocket. Both the older green version and the new red version are shown. This part comes in a pack:
276-3880
276-2252-007
4 Comes in the High Strength 30-Tooth Sprocket packs.
Only one of these packs is needed for Bin 1.
The other packs will go in Bin 3.
High Strength Chain Attachment Link Kit High Strength Chain Attachment Link Kit. 276-7578 6 links Comes in multiple bags of 6 links.
Once all of the parts from the Workcell Kit have been placed into the base of Storage Bin 1, the base will look like this image.
Top down view of the Base of Storage Bin 1 to illustrate how the pieces should be packed.
