V5 Workcell Kit Storage - Bin 2: Electronics and Tools
This article will cover the pieces from the V5 Workcell Kit that will be organized into Storage Bin 2.
There are three components to organizing Storage Bin 2:
V5 Workcell Kit Storage Bin 2 Tray 1 is viewed from above.
Tray 1
V5 Workcell Kit Storage Bin 2 Tray 2 is viewed from above.
Tray 2
V5 Workcell Kit Storage Bin 2 Base is viewed from above.
Base
This article organizes each piece in Bin 2 and provides the following information in a table form from left to right:
  • Part: This is the name of the part. Hyperlinks are provided for replacement parts available to purchase individually at vexrobotics.com.
    Photo: This is an image of the part. Use this for reference while unboxing your kit and building the V5 Workcell.
  • Part Number: If a part comes in a larger kit, bag, or box, the part number of the kit, bag, or box and the individual part number is provided. Use these part numbers to identify your pieces while unboxing and then building the V5 Workcell.
  • Quantity: This is the quantity of each part provided. Use this to ensure you have the correct number of parts in each location in the Bin or Tray while unboxing.
  • Bag Notes: This column provides information about how the part or parts in that kit, bag, or box will be received. If the parts come in a larger kit, bag, or box, an image of the label is provided for reference. Use these for reference when unboxing your kit.
  • Location: This is an image of the Bin or Tray with a highlight on where the part should be placed in that Bin or Tray. This information can also be useful while building the V5 Workcell if a reminder is needed for where a part is located.
    • Helpful Hints: These are provided in the Location column. These hints provide extra context or information on packaging, identifying part numbers, or tips for additional organization.
Storage Bin 2: Tray 1
Part Photo Part Number Quantity Bag Notes Location
V5 Optical Sensor V5 Optical Sensor. This part comes in this pack:
276-7832
Individual part number:
276-7043
4 These come as part of the Workcell Electronics Box
Label for the V5 Workcell Electronics Box, which contains this piece.
Location of this piece is highlighted in the first Tray's top right corner.
Rubber Bumper Rubber Bumper. 276-7499-001 12 Comes in 1 pack of 12 Location of this piece is highlighted on the right side of the first Tray.
V5 Electromagnet V5 Electromagnet. This part comes in this pack:
276-7832
267-7047
1 This comes as part of the Workcell Electronics Box
Location of this piece is highlighted in the first Tray's bottom right corner.
Open End Wrench Open End Wrench. This part comes in this pack:
276-6650-804
267-4350-001
6 These come as part of the Competition Super Kit Tools bag.
This is a clear, unlabeled bag that contains the Open End Wrenches, the Star Drive Keys, and the Star Screwdrivers.
Line Tracker Line Tracker. 276-2154-001 6 Comes in 2 packages of 3 Location of this piece is highlighted on the bottom side of the first Tray.
3 Wire Extension Cable (24") 3 Wire Extension Cable (24 inches). 276-1425-000 8 Comes in 2 packages of 4 Location of this piece is highlighted on the bottom side of the first Tray.
V5 Smart Cable Crimping Tool V5 Smart Cable Crimping Tool. 276-5773 1 Comes individually Location of this piece is highlighted in the center area of the first Tray.
T15 Star Drive Keys T15 Star Drive Key. This part comes in this pack:
276-6650-804
276-5011-001
2 These come as part of the Competition Super Kit Tools bag.
T8 Star Drive Keys T15 Star Drive Key. This part comes in this pack:
276-6650-804
276-5012-001
2
T15 Star Screwdriver
Note: There are various colored versions of the T15 Screwdriver. The color received may not match the listed product photo.
T15 Star Screwdriver. This part comes in this pack:
276-6650-804
276-5236-002
4
V5 Smart Cable Connectors V5 Smart Cable Connectors. 276-5775-001 50 Comes in 1 bag of 50 Location of this piece is highlighted in the first Tray's bottom left corner.
V5 Bumper Switch v2 V5 Bumper Switch v2. 276-4858 2 Comes in 1 bag of 2 Location of this piece is highlighted on the left side of the first Tray.
Limit Switch Limit Switch. 276-2174-000 2 Comes in 1 box of 2 Location of this piece is highlighted on the left side of the first Tray.
Red 5x Pitch Weighted Disk Red 5x Pitch Weighted Disk. This part comes in this pack:
276-7472-804
228-3445-2250
2 36 Disks will come in one bag. Remove two of each color to be placed in this tray.
The other 30 Disks will go into Bin 3.
Parts list for a bag that contains 12 disks of each of the three colors, 36 disks total.
Location of these pieces is highlighted on the top side of the first Tray.
Green 5x Pitch Weighted Disk Green 5x Pitch Weighted Disk. This part comes in this pack:
276-7472-804
228-3450-2250
2
Blue 5x Pitch Weighted Disk Blue 5x Pitch Weighted Disk. This part comes in this pack:
276-7472-804
228-3196-2250
2
3 Wire Extension Cable ( 36") 3 Wire Extension Cable (36 inches). 276-1976-000 8 Comes in 2 packages of 4 Location of this piece is highlighted on the top side of the first Tray.
Potentiometer V2 Potentiometer V2. This part comes in this pack:
276-7832
276-7417-000
Location of this piece is highlighted in the first Tray's top left corner.
Once all of the parts from the Workcell Kit have been placed into tray 1 of Storage Bin 2, tray 1 will look like this image.
Storage Bin 2: Tray 2
Note: Storage Bin 2 uses two trays. Storage Bin 3 does not use a tray. The tray from Bin 3 should be used as Tray 2 of Storage Bin 2.
Silicone Rubber Band #32 Silicone Rubber Band #32. 228-6633-468 10 Comes in 1 pack of 10 Location of this piece is highlighted on the right side of the first Tray.
Intake Roller Intake Roller. Comes in this package:
276-1499
228-6633-000
8 Comes in 1 pack of 8 Location of this piece is highlighted in the first Tray's bottom right corner.
V5 Battery Clip V5 Battery Clip. Comes in this kit:
270-7247-802
276-6020
2 These two parts come in the PLTW V5 Upgrade Kit box
Label for the PLTW V5 Upgrade Kit, which contains this piece.
Helpful Hint: When attaching the V5 Battery, you will only use the two Battery Clips. The other four side attachments that come with the Battery Clips can be used when not using the Robot Brain Mount Assembly (276-7152-002).
300mm V5 Smart Cables 300mm V5 Smart Cable with a label indicating that the Smart Cable's length is written on it. Comes in this package:
276-6364
276-4860-020
3 Comes in the V5 Smart Cables Starter Pack
Label for the V5 Smart Cables (Starter Pack), which contains this piece.
600mm V5 Smart Cables 600mm V5 Smart Cable with a label indicating that the Smart Cable's length is written on it. This part comes in two bags:
276-6364
276-4861
276-4860-030
3 1 comes in the V5 Smart Cables Starter pack.
2 come in the V5 Smart Cables (Long Assortment).
Label for the V5 Smart Cables (Long Assortment), which contains this piece.
900mm V5 Smart Cables 900mm V5 Smart Cable with a label indicating that the Smart Cable's length is written on it. This part comes in two bags:
276-6364
276-4861
276-4860-010
2 1 comes in the V5 Smart Cables Starter pack.
1 comes in the V5 Smart Cables (Long Assortment).
1200mm V5 Smart Cables 1200mm V5 Smart Cable with a label indicating that the Smart Cable's length is written on it. Comes in this package:
276-4861
276-4861-020
1 Comes in the V5 Smart Cables (Long Assortment) pack.
1500mm V5 Smart Cables 1500mm V5 Smart Cable with a label indicating that the Smart Cable's length is written on it. Comes in this package:
276-4861
276-4861-030
2 Comes in the V5 Smart Cables (Long Assortment) pack.
USB Cable (A-Micro) USB Cable (A-Micro). Comes in this kit:
270-7247-802
228-2785
1 This part comes in the PLTW V5 Upgrade Kit box.
V5 Robot Battery Li-Ion 1100mAh V5 Robot Battery Li-Ion 1100mAh. Comes in this kit:
270-7247-802
276-4811
Location of this piece is highlighted in the center area of the second Tray.
V5 Power Cable V5 Power Cable. Comes in this kit:
270-7247-802
276-4817
Pillow Block Pillow Block. Comes in this bag:
276-6820-807
276-2016-001
12 Comes in one bag
Parts list for a bag that contains Pillow Blocks and Lock Bars.
Lock Bar Assembly Lock Bar Assembly. Comes in this bag:
276-6820-807
Individual part number: 276-2016-002
8
V5 3-Wire Expander V5 3-Wire Expander. 276-5299 1 This comes individually Location of this piece is highlighted on the left side of the first Tray.
Plus Gusset Plus Gusset. Comes in this box:
276-6830
276-1110-001
2
The gusset pack includes 4 of each type. Remove two of each gusset type to be placed in this tray.
The other gussets will go into Bin 3.
Comes in the V5 Classroom Structure Kit
V5 Classroom Structure Kit, which contains these pieces.
Location of this piece is highlighted in the second Tray's top left corner.
90 Degree Gusset 90 Degree Gusset. Comes in this box:
276-6830
276-1110-002
2
Angle Gusset Angle Gusset. Comes in this box:
276-6830
276-1110-003
2
V5 Robot Battery Charger V5 Robot Battery Charger. Comes in this kit:
270-7247-802
276-4812
1 These parts come in the PLTW V5 Upgrade Kit box
V5 Smart Cable Stock (8m) V5 Smart Cable Stock (8m). 276-5774 1 Comes in 1 bag Location of this piece is highlighted on the top side of the second Tray.
Once all of the parts from the Workcell Kit have been placed into tray 2 of Storage Bin 2, tray 2 will look like this image.
Storage Bin 2: Base
V5 Robot Brain V5 Robot Brain. Comes in this kit:
270-7247-802
276-4810
This piece is located in the Base of the Storage Bin.
V5 Smart Motor (11w) V5 Smart Motor (11w). Comes in this kit:
270-7247-802
276-4840
4 These parts come in the PLTW V5 Upgrade Kit box
V5 Smart Motor (5.5W) V5 Smart Motor (5.5w). This part comes in this pack:
276-7832
276-4842-000
8 These come as part of the Workcell Electronics Box
4” Zip Ties 4 inch Zip Ties. 276-1032 200 Comes in 2 packs of 100. This piece is located in the Base of the Storage Bin.
Once all of the parts from the Workcell Kit have been placed into the base of Storage Bin 2, the base will look like this image.
