Connecting with App-based VEXcode 123 on iPad
To begin coding the VEX 123 Robot, you'll first need to connect it to VEXcode 123. Below are the steps for connecting and disconnecting the robot.
Connect a VEX 123 Robot to VEXcode 123
Dialogue box asking for permission to use Bluetooth to connect to the robot. The dialogue box reads 'VEXcode 123 would like to use bluetooth, This application uses Bluetooth Low Energy to communicate with your robot.'
When you first launch VEXcode 123, you may get a dialogue box asking for permissions to use Bluetooth. Select OK  to allow the permissions.
Turn on the 123 Robot by pushing the 123 Robot along a surface to “wake” it, as shown in this animation.
VEXcode 123 Toolbar with the Robot icon called out in a red box, to the left of the Start button.
Select the robot icon at the top of VEXcode.
VEXcode 123 with the Robot dropdown menu opened and the Connect button highlighted.
Select Connect.
VEXcode 123 with a dialogue box opened to select the 123 Robot to connect to. Only one robot is shown, and it is highlighted.
A dialogue box will open. Select the name of the 123 Robot that you want to connect to VEXcode 123.
VEXcode 123 with a dialogue box opened to select the 123 Robot to connect to. The 123 Robot has been selected, and the Connect button below is highlighted.
Select Connect after choosing your robot.
VEXcode 123 with an orange Robot icon on the Toolbar to indicate that it is connecting.
The Robot icon will turn orange and a Connecting to: message will appear while the Robot is connecting.
VEXcode 123 with a green Robot icon on the Toolbar to indicate that the robot has connected.
Once the 123 Robot is connected the Robot icon will turn green. The message in the window will say Connected to: and the name of the Robot that is connected to VEXcode 123.
VEXcode 123 with a connected robot and the Robot dropdown menu opened. The battery indicator icon is highlighted.
Underneath the Connected to: message, there is an icon that displays the battery level of the 123 Robot.
Red battery icon indicating a robot with low battery.
Yellow battery icon indicating a robot with medium battery.
Green battery icon indicating a robot with full battery.
The battery indicator displays one of three colors to show the current charge level.
  • Red - Low battery.
  • Yellow - Medium battery.
  • Green - Full battery.
Disconnect a VEX 123 Robot from VEXcode 123
VEXcode 123 with a connected robot and the Robot dropdown menu opened. The Disconnect button is highlighted.
Select Disconnect to disconnect your 123 Robot from VEXcode 123.
If You Are Experiencing Connection Issues
