V5 Workcell Kit Storage - Bin 3: Competition Hardware
This article will cover the pieces from the V5 Workcell Kit that will be organized into Storage Bin 3.
There is only one component to organizing Storage Bin 3:
V5 Workcell Kit Storage Bin 3 Base is viewed from above.
Base
This article organizes each piece in Bin 3 and provides the following information in a table form from left to right:
  • Part: This is the name of the part. Hyperlinks are provided for replacement parts available to purchase individually at vexrobotics.com.
    Photo: This is an image of the part. Use this for reference while unboxing your kit and building the V5 Workcell.
  • Part Number: If a part comes in a larger kit, bag, or box, the part number of the kit, bag, or box and the individual part number is provided. Use these part numbers to identify your pieces while unboxing and then building the V5 Workcell.
  • Quantity: This is the quantity of each part provided. Use this to ensure you have the correct number of parts in each location in the Bin while unboxing.
  • Bag Notes: This column provides information about how the part or parts in that kit, bag, or box will be received. If the parts come in a larger kit, bag, or box, an image of the label is provided for reference. Use these for reference when unboxing your kit.
  • Location: This is an image of the Bin with a highlight on where the part should be placed in that Bin. This information can also be useful while building the V5 Workcell if a reminder is needed for where a part is located.
    • Helpful Hints: These are provided in the Location column. These hints provide extra context or information on packaging, identifying part numbers, or tips for additional organization.
Storage Bin 3: Base
Part Photo Part Number Quantity Bag Notes Location
Red 5x Pitch Weighted Disk Red 5x Pitch Weighted Disk.
This part comes in this pack: 276-7472-804
Individual part number: 228-3445-2250
10 36 Disks will come in one bag.
Two of each color to be placed in Bin 2.
The other 30 Disks will go into Bin 3.
Parts list for a bag that contains 12 disks of each of the three colors, 36 disks total.
This piece is located in the Base of the Storage Bin.
Helpful Hint: Use a large resealable bag to keep the Disks together in this Bin. These can be bagged with all 30 Disks together or in 3 bags separated by color.
Green 5x Pitch Weighted Disk Green 5x Pitch Weighted Disk. This part comes in this pack:
276-7472-804
228-3450-2250
10
Blue 5x Pitch Weighted Disk Blue 5x Pitch Weighted Disk. This part comes in this pack:
276-7472-804
228-3196-2250
10
High Strength Chain Attachment Link Kit High Strength Chain Attachment Link Kit. 276-7578 18 links Comes in multiple bags of 6 links.
Only one bag is needed for Bin 1.
The other bags will be placed in Bin 3.
Gear Kit Gear pieces that are included in the Gear Kit. 276-2169 1 Comes in one box. This piece is located in the Base of the Storage Bin.
30T High Strength Sprocket
Note: This part is currently being transitioned from green to red.
30T High Strength Sprocket. Both the older green version and the new red version are shown. This part comes in a pack:
276-3880
276-2252-007
8 Comes in the High Strength 30-Tooth Sprocket packs.
Label for the High Strength 30-Tooth Sprocket 4-Pack.
Only two of these 4-packs are needed for Bin 3.
The other pack will go in Bin 1.
Red VRC License Plate Red VRC License Plate. This part comes in this kit:
276-7472-803
276-3938-002
1 These parts come in one bag.
Parts list for a bag that contains the Red License Plate, Number Sticker Sheet, and Alphabet Sticker Sheet.
License Plate Alphabet Sheet License Plate Alphabet Sticker Sheet. This part comes in this kit:
276-7472-803
276-3936-001
1
License Plate Number Sticker Sheet License Plate Number Sticker Sheet. This part comes in this kit:
276-7472-803
276-3936-001
1
High Strength Conveyor Chain High Strength Conveyor Chain. 276-7141 18 chains Comes in multiple bags of 6 chains.
15x30 Base Plate 15x30 Base Plate. 276-1341-003 3 These come in three boxes of two Base Plates.
You will need to open one of these boxes while organizing your storage bin to create two sets of three.
5x15 Steel Plate 5x15 Steel Plate. Comes in this box:
276-6830
275-2023-001
2 Comes in the V5 Classroom Structure Kit.
V5 Classroom Structure Kit, which contains these pieces.
2x2x25 Angle 2x2x25 Angle. Comes in this box:
276-6830
276-2232-022
2
1x1x25 Steel Slotted Angle 1x1x25 Steel Slotted Angle. Comes in this box:
276-6830
276-2232-025
2
5x25 Steel Plate 5x25 Steel Plate. Comes in this box:
276-6830
275-1140-001
2
1x2x1x15 Steel C-Channel 1x2x1x15 Steel C-Channel. Comes in this box:
276-6830
276-2232-028
2
1x2x1x25 Steel C-Channel 1x2x1x25 Steel C-Channel. Comes in this box:
276-6830
276-2232-029
2
1x2x1x20 Steel C-Channel 1x2x1x20 Steel C-Channel. Comes in this box:
276-6830
276-2600-003
4
2x2x2x20 U Channel 2x2x2x20 U Channel. Comes in this box:
276-6830
276-6009-001
1
2x2x20 Steel Angle 2x2x20 Steel Angle. Comes in this box:
276-6830
276-2600-001
2
1x25 Steel Bar 1x25 Steel Bar. Comes in this box:
276-6830
275-1141
8
12” Drive Shaft 12 inch Drive Shaft. 276-1149 4 Comes in 1 pack of 4. This piece is located in the Base of the Storage Bin.
Once all of the parts from the Workcell Kit have been placed into the base of Storage Bin 3, the base will look like this image.
Top down view of Storage Bin 3 to illustrate how the pieces should be packed.
