Coding the VEX V5 Workcell in VEXcode V5
VEXcode V5 app icon.
VEXcode V5 is the coding environment for programming the VEX V5 Workcell. Before you begin coding with VEXcode V5, you must first download the software.
VEXcode V5 download page with download options for many platforms, including Chrome Web Store, Windows, Mac, Apple App Store Google Play, and the Amazon appstore.
First navigate to the download page. VEXcode V5 is available for the following devices. Select your device to download and install the software.
Note: for more information on how to install VEXcode V5, view the VEXcode V5 install articles from the VEX Robotics VEX Library.
The article Coding with VEXcode V5 provides links to other articles that will help you start coding the V5 Workcell with VEXcode V5.
VEX V5 Workcell build showing robotic arm, conveyors, disks, and V5 Brain.
The article will cover items such as how to download VEXcode V5, what devices are in the Robot Configuration and how they are used, what the blocks are in the Workspace and how to use them, how to name, save, and download your VEXcode V5 project, as well as other helpful information, such as how to update your firmware if needed.
VEXcode V5 blocks workspace.
For additional information on how to configure the V5 Workcell or use Example Projects, view the Coding with the V5 Workcell section of the VEX Library.
