Using VEX V5 Workcell Example Projects in VEXcode V5
Example projects are a great resource if you are just getting started with coding the V5 Workcell in VEXcode V5, and want to explore different behaviors and functionality of the V5 Workcell. Example projects also allow you to observe how different blocks in VEXcode V5 are used.
VEXcode V5 with the Open Examples option highlighted in the File dropdown menu.
To open an Example Project, select the File menu and choose ‘Open Examples.’
Example Projects menu with the Arm category of projects highlighted.
Icons for many different Example Projects will be shown. Each icon represents a different project and are colored according to the block categories. The Filter bar can be used to quickly find a specific type of example. Select the ‘Arm’ filter to view Example Projects made specifically for the V5 Workcell.
Example Projects menu with the Arm UI Panel example project highlighted.
To open any example, select one from the menu.
VEXcode V5 blocks workspace with an example project opened to show its blocks code.
Blocks for the Example Project will populate in the Workspace. These blocks and their parameters can be changed or removed. Additional blocks can be added to modify the Example Project.
VEXcode V5 with the Devices menu opened after an example project has been selected. There are pre-configured devices shown in the menu.
Note that the Example Project opens with all its devices already pre-configured.
Your device assignments may be configured differently based on if you use the "Standard Config" or a "Custom Config"
VEXcode V5 Toolbar with the Download icon highlighted in between the Brain and Run icons.
Save and download the example to try it on your V5 Workcell.
