Viewing Tutorial Videos in VEXcode IQ
Tutorial videos are a great resource if you are just getting started with VEXcode IQ. They cover specific functionalities of VEXcode IQ, as well as coding concepts.
Viewing a Tutorial Video
VEXcode IQ Toolbar with the Tutorials icon highlighted to the right of the File icon.
To view a video, select ‘TUTORIALS’ from the Toolbar.
Thumbnail for the Use Example Projects and Templates tutorial video in VEXcode IQ.
As an example, select the ‘Using Examples Projects and Templates’ tutorial video.
Tutorial video is open, and the play video icon in the center of the window is highlighted.
Select the play icon on the video window to start the video.
Tutorial video is open, and the Tutorials icon in the top left corner is highlighted.
You can get back to the tutorials from the ‘Tutorials’ icon in the top left of the window.
Tutorial video is open, and the Shrink icon in the top right is highlighted.
You can shrink the window.
Tutorial video is open and shrunk. There is an Expand icon where the Shrink icon used to be.
If the window was shrunk, you can ‘Expand’ the window.
Tutorial video is open, and the Close icon in the top right corner is highlighted.
You can close the window at any time.
Tutorial video is open, and the pause video icon in the center of the window is highlighted.
You can pause the video at any time by hovering over the video and select the pause icon.
Tutorial video is open, and the fullscreen icon on the bottom right is highlighted.
You can expand to full screen.
Tutorial video is open and in fullscreen, and there is an exit fullscreen icon where the fullscreen icon used to be.
To revert from full screen select the collapse icon in the bottom right corner.
