Open a VEXcode V5 C++ Project on Windows
There are several ways to open a C++ project in Windows.
The following article will cover:
  • Open an Existing Project
  • Open a Recent Project
  • Open an Example Project
Select ‘File’ in the Toolbar.
Select ‘Open’ in the drop down menu.
Your device’s File Menu will open. Select ‘Downloads’ or the location where you saved your file. Then, select the desired C++ project file.
Select open.
Your project will open in VEXcode V5.
You can also open a project that has been saved recently by selecting the ‘Open Recent’ option. When selected, a menu with recently saved projects will open.
Note: C++projects will have a .v5cpp extension.
From C++ text project, select ‘File’ in the Toolbar.
Select ‘Open Examples’ in the drop down menu.
Select a Template or an Example Project.
Note: Templates and Example Projects are used for the following.
  • Templates configure the motors and sensors on your robot for the project.
  • Example projects are premade projects that are ready to download and run.
This project features the Clawbot (Drivetrain 2-motor, No Gyro) Template.
Once selected, the Template or Example Project will open.
