Troubleshooting Playground Selection in Safari-based Web Browsers
For non-Safari browsers, a default Playground is loaded automatically when the Playground window is opened.
When using Safari, a default Playground is not automatically loaded when the Playground window is opened. Instead, the user must select the Playground they want to use.
Selecting a Playground in Safari
VEXcode VR Playground toolbar showing the Start and Step controls
Select the Playground, Start, or Step icons in the Toolbar to open the Playground window.
Playground menu in VEXcode VR with available virtual environments listed
Once the Playground Window opens, there will be a message to select a Playground to get started.
Playground selection menu in VEXcode VR showing available playground options
Open the drop-down Playground menu and select the desired Playground.
VEXcode VR Playground selection screen displayed in Safari
The Playground will load and the project can be started.
VEXcode VR will remember the Playground previously loaded. If the window is closed and then reopened, the previous Playground selected will be reloaded.
Changing Playgrounds
Playground menu in VEXcode VR with available playgrounds listed
To change Playgrounds, open the drop-down Playground menu and select a new Playground.
Reload the VEXcode VR Playground page in Safari
The page may reload due to Safari memory limitations.
VEXcode VR Playground open with the virtual robot displayed
After the page has reloaded, the new Playground will open.
Note: While reloading, the page may momentarily show an empty project. This is only temporary. The project created will be retained and reloaded.
Opening an Example Project in Safari
Playground selection menu in VEXcode VR for choosing a playground in a new project
VEXcode VR with a playground selected and the Playground Auto Opens example open
When a user opens an example project in Safari, the corresponding Playground will automatically open.
