Auto Backup Feature in VEXcode VR
In order to keep your progress while working on a project, VEXcode VR has an automatic backup feature. This feature works for both Blocks projects and Text projects.
If you are in a classroom that shares devices and do not want a student to see the previous student’s code, start a new project before closing the VEXcode VR tab.
Please note that if you have multiple VEXcode VR tabs open, the auto backup will ONLY store the project in the last tab that was closed. The other projects will not be backed up.
Auto Backup in a Blocks Project
While working on a project in VEXcode VR, your browser may unexpectedly or accidentally be closed. To restore your project, simply reopen VEXcode VR in your browser.
Note: This auto backup will only work if you use the same browser before and after the crash. If your Safari window closes unexpectedly, you cannot open a Chrome window and see the restored project.
Once the project has been restored, it is recommended that you save the project.
Save the Project block in the File menu of VEXcode VR
If you have selected a block or modified a restored Blocks project and attempt to open a new Blocks or Text project, you will be prompted to save the project.
Dialog to save the current VEXcode VR project as a backup or cancel.
Note: If you restore a project and immediately attempt to open a new Blocks or Text project, you will not be prompted to save.
Auto Backup in a Text Project
VEXcode VR will automatically open in the text project mode with your project restored.
Save project button in VEXcode VR
If you have not yet saved the project and attempt to open a new Blocks or Text project, you will be prompted to save the restored project.
