Opening and Saving Projects on an Android
This article will cover the following topics:
  • Create a New Project
  • Open an Example Project
  • Open a Recent Project
  • Open an Existing Project
  • Save a Project
    • Save Using the File Menu
    • Save as a Copy
A new project opens when VEXcode GO is opened. But, a new project can also be opened from the File Menu.
Select ‘New Blocks Project’ from the File Menu.
Note: when creating a new project, a prompt will appear asking to save if the current project has not already been saved. See the ‘Save a Project’ section for details on how to save a project.
Open an example project by selecting ‘Open Examples’ from the File menu.
Open the list of recent projects from the File menu.
Then, select a recent project to open it.
Select ‘Open’ from the File Menu to open an existing project.
Select the file to open a project.
The project will open in the Workspace, and the name of the project will appear in the Project Name area.
Save a Project
A project can be saved in VEXcode GO by using the File Menu and Save as a copy.
Open the File menu and select ‘Save.’
The device’s file menu will then open.
Use the keypad to name your new project.
Select ‘Save’ after naming the project.
After a project is saved, VEXcode GO will automatically save all changes in a project.
Save a Copy
To make a copy of a project under a different name or in a different location, select ‘Save As’ in the File menu.
