Connecting a VEX GO Brain to an Android
It takes just a few steps to connect a GO Brain to your Android device.
Connect the GO Brain to the Battery.
Turn on the GO Brain by pressing the button in the center of the Brain.
Launch VEXcode GO.
Open VEXcode GO and select the Brain icon in the Toolbar.
Select ‘Connect.’
When selecting ‘Connect,’ you may receive a prompt asking to verify access. Select ‘Allow.’
A list of available GO Brains will appear. Select the name of the Brain you want to connect to.
Once a Brain is chosen, select the ‘Connect’ button.
The Brain icon will turn orange and a ‘Connecting to:’ message will appear while the Brain is connecting.
Once the Brain is connected, the icon will turn green. The message in the window will say ‘Connected to:’ and list the name of the GO Brain that is connected to this Android device.
To disconnect from a Brain, select ‘Disconnect.’
If you are experiencing connection issues, select ‘Help Connecting VEX GO.’
