Updating the VEX GO Brain's Firmware
The firmware on one or multiple GO Brains can be updated at a time using VEXcode or the VEX Classroom App.
Update Firmware in VEXcode
Navigate to code.vex.com and connect your GO Brain to VEXcode.
Updating Robot Firmware window in VEXcode showing the status Reconnecting with a progress bar at 10%. The window reads Do not close VEXcode during the update. Keep this page open in the foreground to ensure the update completes successfully.
When using an iPad or Android device, VEX GO will automatically update when the GO Brain is connected to VEXcode.
For more information on how to connect your GO Brain to VEXcode, go here.
A GO Brain that is updating will blink green and red while it is updating. It will return to solid green once the update is complete. This process is shown in this video.
Note: The update length has been shortened for the animation. An actual firmware update may take up to 2 minutes.
Update Firmware Using VEX the Classroom App
Navigate to your device’s app store and search for VEX Classroom to download the app if you have not done so already.
Note: The VEX Classroom App is available on the following platforms:
Scan for VEX Devices button in the VEX Classroom App.
Select Scan for VEX Devices in the VEX Classroom app.
Update All button in the VEX Classroom App.
Select Update All to update all detected GO Brains' firmware.
GO Brain named GO 2 in the VEX Devices list shown in orange with an exclamation point icon and an update progress bar at 18%. The Locate icon is grayed out.
A progress bar will appear to show the progress of the update. All other options will remain unavailable until the update has finished.
A brain that is updating will blink green and red while it is updating. It will return to solid green once the update is complete. This process is shown in this video.
GO Brain named GO 2 in the VEX Devices list shown in green with a check mark and a battery level of 100%, indicating the update is complete.
Once the update is complete, the brain name and icon will now show green in the app. The Update option will now be unavailable since the brain is now up to date.
Brain with its power button highlighted in a red box and glowing green to indicate that the Brain has finished updating.
The button on top of the GO Brain will remain a solid green once the update is complete.
