Using the Code Viewer in VEXcode VR
Using the Code Viewer in VEXcode VR is easy and helpful.
How to open the Code Viewer
Code Viewer showing the current VEXcode VR project blocks
To launch VEXcode VR, go to vr.vex.com. The platform defaults to the Blocks interface.
Code Viewer showing the project’s block code next to the VR Playground
Select the Code Viewer icon to open the Code Viewer window.
Code Viewer displaying the VR robot’s block-based project code
The Code Viewer window displays the Python version of the Blocks project.
Code Viewer showing the VR robot project’s block code
Hide the Code Viewer window when finished by selecting the right arrow next to the Help icon.
How text commands are added when blocks are added
Code Viewer showing the project’s block code next to the Playground in VEXcode VR
Add a drive block to the project.
Code Viewer showing the current VEXcode VR project blocks for the virtual robot
Code Viewer showing the project’s block code in VEXcode VR
Notice that the print command will also be added to the Command Viewer window.
How text commands are deleted when blocks are deleted
Delete the [Print] block from the VEXcode VR project.
Note: for more information on how to delete a block, view the Delete a Block article from the VEX Library.
Notice that the print command will also be deleted from the Command Viewer window.
