The VEX GO Electromagnet is used to transport Disks.
The following article will cover:
- How the Electromagnet is Used
- Transport Disk Example Project
Note: In this article, the example project uses the Code Base - Eye + Electromagnet GO Build.
The Electromagnet is used to have your robot be able to pick up and drop Disks.
The [Energize electromagnet] block is used to ‘boost’ and ‘drop’ Disks.
The ‘boost’ setting allows you to pick up a Disk.
The ‘drop’ setting allows you to release a Disk.
The code below will pick up and transport a Disk to a new location with the Code Base.
