When starting to create a project in VEXcode GO, blocks from the Drivetrain and Sensing categories will not appear in the Toolbox until a Super Car has been configured.
You can only configure one build per project.
The following article will cover:
- Adding a Super Car
- Deleting a Super Car
Adding a Super Car
To configure a Super Car, select the Devices button to open the Devices window.
Select ‘Add a device.’
Select ‘SUPER CAR.’
Once the Super Car is selected, a list of ports will appear. Check that all assigned ports match your finished build.
Select ‘DONE’ to complete the configuration or ‘CANCEL’ to return to the Devices menu.
Note: Selecting 'Cancel' will close the Super Car Configuration and take you back to the Devices window with no devices configured.
Now that the Super Car has been configured, blocks from the Drivetrain and Sensing categories appear in the Toolbox.
A Super Car can also be deleted by selecting the ‘DELETE’ option at the bottom of the screen.
