When you get your VEX GO Kit with Storage, there are a few things you can do to get yourself organized and started. This article will cover the basics of unpacking your Kit and getting ready to use VEX GO with your students.
Get Organized
Your VEX GO Kit with Storage comes presorted in the clear-lidded, stackable boxes, saving you from having to sort and organize the pieces yourself. Every classroom is different, but here are some organizing tips that can help you get started:
- Label Your Kits - if you have one Kit with Storage, it’s a good idea to label both boxes with your classroom or your name. If you have multiple Kits with Storage, label the boxes (Kit 1, Kit 2, etc.) so that they stay together when students are using them.
- Label Your Brains - if you have multiple Kits with Storage in your classroom, take a moment to label each Kit and the Brain with the same name. With a sticker label or piece of tape and a marker, making the name of the Brain clear will help students when they need to connect their VEX GO Brain to their devices.
- You will be able to Rename the Brain using the VEX Classroom App, so you can choose any name you like, or use student names if you know the groupings that you will be assigning. (Read on to learn more about the VEX Classroom App).
Charge Your Battery
Each Kit with Storage contains a VEX GO Battery and Charger. The charging cable may not be in the parts storage box itself, but will be included in the box your order ships in. You should charge your battery so that it is ready for use. Read the Using the VEX GO Battery Knowledge Base article as a guide for how to charge your battery and to learn what the different indicator lights mean.
Using VEXcode GO
Lastly, you will need to access VEXcode GO, the block based coding interface used with VEX GO, and the VEX Classroom App. VEXcode GO can be downloaded and installed on a device, or run through a browser.
To install VEXcode GO, or access the browser link, visit code.vex.com and select 'Download.'
Then, select the button that matches your device, (or the browser option), and download the app onto your device.
Note: VEXcode GO is the interface that students will use to code their VEX GO robots, so it will need to be installed, or able to be accessed via the browser, on each of the student devices that will be used with VEX GO in your classroom.
Download the VEX Classroom App
To install the VEX Classroom App, visit the App Store on your device, and search for ‘VEX Classroom.’ Download the VEX Classroom App.
Note: The VEX Classroom App is ONLY for teacher use, so it should be installed on only the teacher’s device or smartphone.
For more information about the features of the VEX Classroom App and how to use it, see the Using the VEX Classroom App Knowledge Base article.
