Accessing Help in VEXcode GO
VEXcode GO Toolbar with the Help icon highlighted to the right of the Monitor icon.
Help explains what a block does and includes information on how to use the block in a project.
To access Help, select the Help icon in the top right of the Toolbar.
VEXcode GO with the Help menu opened and no block selected. The Help menu has a message that reads 'Select a block to see more information'.
The Help window will open. Until a block is selected, the Help window will remain blank.
VEXcode GO blocks Toolbox with the Forever block shown and highlighted.
Select any block that you want to learn more about.
VEXcode GO with the Help menu opened and the Forever block selected. Descriptions of the block and how it can be used are shown along with images of example uses.
Once a block is selected, the information about that block will appear in the Help window.
VEXcode GO with the Help menu opened and the Close Menu arrow in the top right corner highlighted.
Hide the Help menu when finished by selecting the right arrow next to the Help icon.
