Using the VEX GO Switch
Using the Switch allows you to bring the VEX GO system to life without programming.
Use the Switch With a Motor
Switch Port
Using a Motor with the Switch allows you to control the Motor without the need for programming.
There are two ports on the Switch. A Smart Port to connect a Motor or LED Bumper and an orange Battery Port to connect a Battery.
GO Switch Motor
Connect a Motor to the Switch by inserting the Motor Cable into the Smart Port on the Switch.
Black Connection
Ensure that the Motor Cable is fully inserted into the Smart Port on the Switch. A ‘click’ sound will ensure that the cable is seated fully into the Smart Port.
GO Brain Battery
To control a Motor with the Switch, ensure a Motor and Battery are connected to the Switch.
There are three settings on the Switch
Switch Forward
‘+’ : rotates the Motor in the forward direction.
Switch
Neutral: turns the Motor off.
Switch reverse
‘-’ : rotates the Motor in the reverse direction.
View all three settings of the Switch.
Use the Switch With the LED Bumper
GO Switch Bumper
Connect the LED Bumper to the Switch by inserting the LED Bumper Cable into the Smart Port on the Switch.
Black Connection
Ensure that the LED Bumper Cable is fully inserted into the Smart Port on the Switch. A ‘click’ sound will ensure that the cable is seated fully into the Smart Port.
GO Switch Battery Bumper
To control the LED Bumper with the Switch, ensure the LED Bumper and Battery are connected to the Switch.
There are three settings on the Switch when connected to the LED Bumper
GO Switch Green
‘+’ : sets the LED Bumper color to green.
GO Switch Neutral
Neutral: turns the LED Bumper off.
GO Switch Red
‘-’ : sets the LED Bumper color to red.
