Using the Switch allows you to bring the VEX GO system to life without programming.
Use the Switch With a Motor
Using a Motor with the Switch allows you to control the Motor without the need for programming.
There are two ports on the Switch. A Smart Port to connect a Motor or LED Bumper and an orange Battery Port to connect a Battery.
Connect a Motor to the Switch by inserting the Motor Cable into the Smart Port on the Switch.
Ensure that the Motor Cable is fully inserted into the Smart Port on the Switch. A ‘click’ sound will ensure that the cable is seated fully into the Smart Port.
There are three settings on the Switch
‘+’ : rotates the Motor in the forward direction.
Neutral: turns the Motor off.
‘-’ : rotates the Motor in the reverse direction.
View all three settings of the Switch.
Use the Switch With the LED Bumper
Connect the LED Bumper to the Switch by inserting the LED Bumper Cable into the Smart Port on the Switch.
Ensure that the LED Bumper Cable is fully inserted into the Smart Port on the Switch. A ‘click’ sound will ensure that the cable is seated fully into the Smart Port.
To control the LED Bumper with the Switch, ensure the LED Bumper and Battery are connected to the Switch.
There are three settings on the Switch when connected to the LED Bumper
‘+’ : sets the LED Bumper color to green.
Neutral: turns the LED Bumper off.
‘-’ : sets the LED Bumper color to red.
