Using Comments in VEXcode GO
Comments are usually added to projects to explain what a programmer wanted parts of the project to do. So they are helpful when collaborating and troubleshooting.
Drag a [Comment] block and attach it to any block in a stack.
Screenshot of the 'Add Comment' feature in VEX Knowledge Base, illustrating how to add comments in Block Tutorials under the GO category.
Type any text, numbers, or symbols into the [Comment] block.
Screenshot showing the comment block interface with instructions to click outside the block or press 'Return' to finish editing a comment, as part of the Block Tutorials in the GO category.
When you finish the comment, click anywhere outside of the [Comment] block, or press 'Return' to finish editing the comment.
Screenshot of a VEX Robotics block tutorial interface, displaying various programming blocks and options for creating a robot program, with a focus on user-friendly design and functionality.
Note: The inside of the [Comment] block will turn from white to gray when finished.
