It takes just a few steps to connect a GO Brain to your iPad.
- Connect the GO Brain to the Battery.
- Turn on the GO Brain by pressing the button in the center of the Brain.
- Launch VEXcode GO.
- When launching VEXcode GO, you may receive a prompt asking to verify Bluetooth usage. Select ‘OK.’
- Open VEXcode GO and select the Brain icon in the Toolbar.
- Select ‘Connect.’
- A list of available GO Brains will appear. Select the name of the Brain you want to connect to.
- Once a Brain is chosen, select the ‘Connect’ button.
- The Brain icon will turn orange and a ‘Connecting to:’ message will appear while the Brain is connecting.
- Once the Brain is connected, the icon will turn green. The message in the window will say ‘Connected to:’ and list the name of the GO Brain that is connected to this iPad.
- To disconnect from a Brain, select ‘Disconnect.’
- If you are experiencing connection issues, select ‘Help Connecting VEX GO.’
