This article will cover the following topics:
- Create a New Project
- Open an Example Project
- Open an Existing Project
- Save a Project
- Save Using the File Menu
- Save as a Copy
A new project opens when VEXcode GO is opened. But, a new project can also be opened from the File Menu.
Select 'New Blocks Project' from the File Menu.
Note: When creating a new project, a prompt will appear asking to save if the current project has not already been saved. See the Save a Project section for details on how to save a project.
Open an example project by selecting ‘Open Examples’ from the File menu.
Select 'Open' from the File Menu to open an existing project.
Select the file to open a project.
The project will open in the Workspace, and the name of the project will appear in the Project Name area.
Save a Project
A project can be saved in VEXcode GO by using the File Menu and Save as a copy.
Open the File menu and select ‘Save.’
The iPad’s file menu will then open. Navigate to the folder where you want to save the project. Then select ‘Create Document.’
Note: If your iPad first goes to the Recents screen, select ‘Browse’ to find the screen above.
If your iPad first goes to the main iCloud Drive folder, select the VEXcode GO folder to Create Document and save your project inside of it.
Use the keypad to name your new project.
Select ‘OK’ after naming the project.
After a project is saved, VEXcode GO will automatically save all changes in a project.
Save a Copy
To make a copy of a project under a different name or in a different location, select ‘Save As’ in the File menu.
