Using the Share and Feedback Buttons in VEXcode VR
Users can easily share the content of their Blocks project in VEXcode VR by using the Share button. Users can also easily provide feedback to VEX to help with the program’s continual improvement by using the Feedback button.
Note: The Share feature is currently unavailable for Android devices.
What is the Share button
Share menu with options to copy a project link and submit feedback
The ‘Share’ button allows users to create a .pdf document of their Blocks project to be shared. The new document can be shared with a teacher via email/Classroom Management System, a fellow student, or printed for an Engineering Notebook.
How to use the Share button
Share button in VEXcode VR for sharing the current project
Once you are at the point where you would like to share your Blocks project, select the ‘Share’ button.
Share and Feedback buttons on the VEXcode VR toolbar
Enter your name, assignment information and any notes you want to include. Then select, "Download".
Share and Feedback buttons in the VEXcode VR toolbar
This will download a .pdf document of your project on your device. You can access the .pdf document from your download location and it can be easily shared to many places.
What is the Feedback button
Feedback button in the VEXcode VR toolbar for sending comments or reporting issues
The Feedback button provides a quick and easy way to provide feedback to VEX. This feedback will provide valuable information such as requesting a new feature, discussing something that is not working, and it can provide valuable diagnostics about your issue.
How to use the Feedback button
Feedback menu with options to report a bug or suggest a feature
If at any time you want to provide feedback to VEX, select the Feedback button.
VEXcode VR toolbar with Share and Feedback buttons highlighted
This will open up the feedback window which has a number of options.
You can rate your experience as positive or not positive.
Positive feedback button in VEXcode VR toolbar
If positive is selected, the smile face will highlight.
Feedback button used to send comments about VEXcode VR
If the not positive is selected, the frown face will highlight.
Share and Feedback buttons on the VEXcode VR toolbar above the workspace
There is a text window to enter the feedback you would like to provide for VEX.
Email draft with a VEXcode VR project link ready to share from Tutorials
There is a check box option to include your email for a response.
Toolbar with Share and Feedback buttons in VEXcode VR
There is a checkbox which allows you to provide VEX with more technical information from your project. If reporting an issue, it is important to include diagnostic data to help identify the problem.
For anyone interested in the Privacy Policy, select the link within the window.
Privacy Policy page explaining how VEXcode VR uses and protects user data
This link will bring you to the most current Privacy Policy.
Share button used to copy or send a VEXcode VR project link
Once you have provided your feedback select the ‘Send’ button.
VEXcode VR toolbar showing the Share and Feedback buttons
This will provide you with a message that your feedback was sent. Select the ‘Close’ button to return to your project.
