Using the Code Viewer - Python Tutorials
Using the Code Viewer in VEXcode V5 is easy and helpful.
The following article will cover:
  • How to open the Code Viewer
  • How text commands are added when blocks are added
  • How text commands are deleted when blocks are deleted
How to open the code viewer
Launch VEXcode V5.
VEXcode V5 Icon
The platform defaults to the Blocks interface.
V5 Blocks interface
Select the Code Viewer icon to open the Code Viewer window.
code viewer icon
The Code Viewer window displays the Python version of the Blocks project.
Code viewer callout
Hide the Code Viewer window when finished by selecting the right arrow next to the Help icon.
close codeviewer
How text commands are added when blocks are added.
Add a [Print] block to the project.
print hello
open code viewer
Notice that the print command will also be added to the Code Viewer window.
added to window
Delete the [Print] block from the VEXcode IQ project.
Delete print block
Note: for more information on how to delete a block, view the Delete a Block article from the Knowledge Base.
Notice that the print command will also be deleted from the Command Viewer window.
deleted code
