Coding with VEX V5 - Get Started with VEX V5
VEXcode V5 is the coding environment for programming the VEX V5 Robot. The following article provides links to other articles that will help you start coding with VEXcode V5.
Coding with VEX V5
These articles will take you through the process of installing VEXcode V5 on your device, creating and saving projects, and how to access the key features in VEXcode V5.
