When working in VEXcode IQ, it is important to understand how to save a C++ project on a Windows device.
Using ‘Save’
Project name window
Saving a VEXcode IQ C++ project is easy. First, select the project name window.
Save dialog
A Save dialog window will open.
Drive forward save
Name your project by typing in your device's Save dialog window.
Note: notice the ‘Save as’ type is ‘VEXcode IQ C++ Project.’ All VEXcode IQ C++ files will have this ‘Save as’ type.
Download location
Select the destination, such as the Downloads folder.
Select save
Then select ‘Save.’
Downloads
The file will save to the chosen destination on your device.
Updated name
The updated project name will be visible in the project name window.
Saved icon
Once a project is saved, VEXcode IQ will automatically save all changes in a project.
Note: Whenever there is an unsaved project, VEXcode IQ will prompt users to save their work if the user attempts to:
  • Close VEXcode IQ
  • Create a new project
  • Open another project
  • Download a project to the IQ Brain
Using ‘Save As’
Save as
You can also use the ‘Save As’ option from the File menu to make a copy of a project under a different name or in a different location.
