Save a C++ Project on Windows - Open and Save C++ Projects - VEXcode IQ
When working in VEXcode IQ, it is important to understand how to save a C++ project on a Windows device.
The article will cover:
  • Using ‘Save’
  • Using ‘Save As’
Using ‘Save’
Saving a VEXcode IQ C++ project is easy. First, select the project name window.
Project name window
A Save dialog window will open.
Save dialog
Name your project by typing in your device's Save dialog window.
Drive forward save
Note: notice the ‘Save as’ type is ‘VEXcode IQ C++ Project.’ All VEXcode IQ C++ files will have this ‘Save as’ type.
Select the destination, such as the Downloads folder
Download location
Then select ‘Save.’
Select save
The file will save to the chosen destination on your device.
Downloads
The updated project name will be visible in the project name window.
Updated name
Once a project is saved, VEXcode IQ will automatically save all changes in a project.
Saved icon
Note: Whenever there is an unsaved project, VEXcode IQ will prompt users to save their work if the user attempts to:
  • Close VEXcode IQ
  • Create a new project
  • Open another project
  • Download a project to the IQ Brain
Using ‘Save As’
You can also use the ‘Save As’ option from the File menu to make a copy of a project under a different name or in a different location.
Save as
