Using the Playground Timer in VEXcode VR
The Playground Timer feature in VEXcode VR can be used in many different scenarios. It displays the run time for a project on any Playground, which can be used as a measure of code efficiency in student iteration of coding activities. It can also be used as a measure of project success in VEXcode VR Competitions in the Classroom.
How to Use the Playground Timer
Playground timer showing elapsed time in seconds
The Playground Timer in VEXcode VR can be found in the lower left corner of the Playground window.
Playground timer in the upper-right corner of VEXcode VR
The Playground Timer in the Playground window of VEXcode VR begins when the ‘Start’ arrow is selected.
Playground timer on the VEXcode VR toolbar in the upper-right corner
Or, the ‘Start’ icon is selected in the Toolbar.
Playground timer displayed in the Playground Features panel next to the coding workspace and virtual robot
The Playground Timer will continue to run until the ‘Stop’ button is selected.
Stop Project block added after the stack to stop the Playground Timer when the project ends
Or, the [Stop project] block is used in the project.
Stop button used to stop the Playground Timer in VEXcode VR
Or, the ‘Stop’ icon is selected in the Toolbar.
How to Reset the Playground Timer
Playground timer displayed in the Monitor Console while a VEXcode VR project runs
Once the project has been stopped, the Playground Timer will reset with the rest of the Playground. Select the ‘Reset’ button to reset the Playground.
Note: the Playground Timer cannot be reset while a project is running.
Playground timer reset to 0:00
Once the ‘Reset’ button has been selected, the Playground Timer and Playground will reset, and the timer will go back to 00:00:0.
Uses for the Playground Timer
Playground Timer displayed in the Brain Monitor during a VEXcode VR project
The Playground Timer can offer a measure of code efficiency for students. By watching the Playground Timer to see how long it takes the VR Robot to run a project, students can have a way to measure if iterations of their code are having the desired effect.
The Playground Timer can also be used to add an element of competition to VEXcode VR Activities.
For more information about classroom competitions, see the article, Implementing VEXcode VR Competitions in the Classroom.
