Preparing to Download a Project in VEXcode IQ
Here is a list of tasks you should perform prior to downloading a VEXcode project to ensure that you have everything is ready before using your VEX IQ Brain.
Before downloading a VEXcode project to the VEX IQ Brain, check each of the following:
  • Are all the motors and sensors plugged into the correct port?
  • Are the smart cables fully inserted into all of the motors and sensors?
  • Is the Brain turned on?
  • Is the battery charged?
Screenshot of a tile depicting a cursor clicking on an example project.
VEXcode IQ has example projects and templates that you can use. In this tutorial video, see how you can use example projects and templates in VEXcode IQ.
VEXcode IQ Forward (mm) example project thumbnail.
If you have a VEX IQ Clawbot built, open the "Forward (mm)" example project and download the project to the VEX IQ Brain.
VEXcode IQ Playing Notes example project thumbnail.
If you do not have a robot built open the Playing Notes example project and download the project to the VEX IQ Brain.
