Pre-Downloading a Project Checklist in VEXcode IQ
Here is a list of tasks you should perform prior to downloading a VEXcode project to ensure that you have everything is ready before using your VEX IQ Brain.
Before downloading a VEXcode project to the VEX IQ Brain, check each of the following:
  • Are all the motors and sensors plugged into the correct port?
  • Are the smart cables fully inserted into all of the motors and sensors?
  • Is the Brain turned on?
  • Is the battery charged?
VEXcode IQ has example projects and templates that you can use. In the following tutorial video see how you can use example projects and templates in VEXcode IQ.
Forward (mm)
If you have a VEX IQ Clawbot built, open the "Forward (mm)" example project and download the project to the VEX IQ Brain.
Sound Example Project
If you do not have a robot built open the Playing Notes example project and download the project to the VEX IQ Brain.
