Open a C++ Project on Chromebook - Open and Save C++ Projects - VEXcode IQ
Users can open a project in VEXcode IQ in different ways:
  • Opening an Existing Project
  • Opening an Example
Open an existing project by selecting ‘Open’ from the File menu.
File menu open
Your device’s File window will open. Select the location where you saved your file. Notice that VEXcode IQ C++ projects have the .iqcpp extension. Then, select the desired .iqcpp project file.
Changing Velocities
Select open.
Changing velocities open
Your project will open in VEXcode IQ.
Project open
Opening an Example Project
Open the File menu and select ‘Open Examples.’
File menu
Then, select an example project to open it.
Examples in VEXcode IQ
Note: when opening a project, a prompt will appear asking to save if the current project has not been saved yet.
For more information on Example Projects, view the Using C++ Example Projects and Templates article in the Knowledge Base.
