Using the Code Viewer - Blocks Tutorials - VEXcode IQ
Using the Code Viewer in VEXcode IQ is easy and helpful.
The following article will cover:
  • How to open the Code Viewer
  • How text commands are added when blocks are added
  • How text commands are deleted when blocks are deleted
Launch VEXcode IQ.
VEXcode IQ Icon
The platform defaults to the Blocks interface.
Launch VEXcode
Select the Code Viewer icon to open the Code Viewer window.
The Code Viewer window displays the C++ version of the Blocks project.
Code Viewer
Hide the Code Viewer window when finished by selecting the right arrow next to the Help icon.
Minimize Code Viewer
Add a [Print] block to the project.
Add a print block
Print Command View Window
Notice that the print command will also be added to the Command Viewer window.
C plus plus version
Delete the [Print] block from the VEXcode IQ project.
Remove a Block
Note: for more information on how to delete a block, view the Delete a Block article from the Knowledge Base.
Notice that the print command will also be deleted from the Command Viewer window.
Code Removed
