Connecting the V5 Brain to a Computer via USB
In order to program the V5 Brain, a successful connection needs to be established between the V5 Brain and a device via a Micro-USB cable.
Gathering the Components
Brain that is connected to both a laptop computer using a Micro-USB cable and a V5 Battery using a V5 Battery Cable.
Gather the Required Components
  • A working Micro-USB cable
  • V5 Brain
  • V5 Battery
  • V5 Battery Cable
  • Windows, Mac, or Chromebook Computer
Connecting Components
V5 Brain is powered on and connected to a V5 Battery.
Connect the V5 Battery to the V5 Brain
Connect the V5 Brain to the V5 Battery using the battery cable. Ensure the connection is secure.
Connect the Micro-USB cable to the V5 Brain
Close up of the connection ports on the V5 Brain, with a Micro-USB cable and a V5 Battery Cable currently connected.
Connect the V5 Brain to a device using the Micro-USB cable.
Make sure the V5 Brain is connected to a charged V5 Battery and turned on.
Connect the Micro-USB Cable to a Device
Connect the other end of the Micro-USB cable to the Computer’s USB port.
Confirm a successful connection
VEXcode V5 Toolbar with the green Brain icon highlighted, indicating that the Brain is connected.
A successful connection is confirmed when the Brain Status Icon in the Toolbar is green.
