Open a Python Project on macOS - Open and Save Python Projects
There are several ways to open a Python project on a MacOS device.
The article will cover:
  • How to Open a Python Project in VEXcode V5 (MacOS)
    • Open an Existing Project
    • Open a Recent Project
    • Open an Example Project
A Python project can be opened in the following ways.
Select ‘File’ in the Toolbar.
File menu
Select ‘Open’ in the drop down menu.
Open menu
Your device’s File Menu will open. Select ‘Downloads’ or the location where you saved your file. Notice that VEXcode V5 Python projects have the .v5python extension. Select the desired .v5python project file.
File open
Select open.
File open select
Your project will open in VEXcode V5.
You can also open a project that has been saved recently by selecting the ‘Open Recent’ option. When selected, a menu with recently saved projects will open.
File open recent
File menu
Select ‘Open Examples’ in the drop down menu.
Open examples
Select a Template or an Example Project.
Example menu
Note: Templates and Example Projects are used for the following.
  • Templates configure the motors and sensors on your robot for the project.
  • Example projects are premade projects that are ready to download and run.
Once selected, the Template or Example Project will open. This project features the Clawbot (Drivetrain 2-motor, No Gyro) Template.
clawbot template
template in workspace
For more information about example projects, select the 'Tutorials' button in the Toolbar.
Tutorials button
Then, scroll down and select the 'Using Example projects' tutorial video.
Using examples
