Saving a V5 Python Project on macOS
When working in VEXcode V5, it is important to understand how to save a project on a macOS device.
Ways to Save
You can save your project in VEXcode V5 in different ways:
VEXcode V5 Toolbar with the File menu open and the Save option highlighted. Save is the fifth option in the menu, below New Blocks Project, New Text Project, Open, and Open Examples.
Option 1: Selecting Save in the File menu.
VEXcode V5 Toolbar with the Download icon highlighted in between the Brain and Run icons.
Option 2: Downloading a new project.
VEXcode V5 Toolbar with the project name field highlighted. To the right of the Project Name a label reads Not Saved.
Option 3: Naming a new project by selecting the project name window.
VEXcode V5 Project Name dropdown menu opened where the name can be changed. The menu's Save button is highlighted.
Then select the Save button.
Saving a Project
The device's Save As menu is open and set to save to the Downloads folder.
Choose one of the ways above to save a new project, then a Save As dialog window will open.
The device's Save As menu is open and set to save to the Downloads folder. The Save As field that can be used to name the project is highlighted.
Name your project by typing in your device's save dialog window.
The device's Save As menu is open and set to save to the Downloads folder. The Where field that can be used to set the destination is highlighted.
Select the destination, such as the Downloads folder.
The device's Save As menu is open and set to save to the Downloads folder. The project has been renamed to Drive Project. The Save button in the bottom right is highlighted.
Then select Save.
VEXcode V5 Toolbar with the project name field highlighted and changed to Drive Project.
The updated project name will be visible in the project name window.
VEXcode V5 Toolbar with the project name field changed to Drive Project. The label to the right is highlighted and reads Saved.
Once a project is saved, VEXcode V5 will automatically save all changes in a project.
VEXcode V5 unsaved project prompt that reads Your project was never saved. Save now? Below there are two buttons, one reads Discard and the other reads Save.
Note: Whenever there is an unsaved project, VEXcode V5 will prompt users to save their work if the user attempts to:
  • Close VEXcode V5
  • Create a new project
  • Open another project
Using 'Save As'
VEXcode V5 Toolbar with the File menu open and the Save As option highlighted. Save As is the sixth option in the menu, below New Blocks Project, New Text Project, Open, Open Examples, and Save.
You can also use the Save As option from the File menu to make a copy of a project under a different name or in a different location.
