Saving a V5 Python Project on Chromebook
When working in VEXcode V5, it is important to understand how to save a project on a Chromebook.
Using ‘Save’
VEXcode V5 Toolbar with the project name field highlighted. To the right of the Project Name a label reads Not Saved.
Saving VEXcode V5 Python projects is easy. First, select the project name window.
The device's Save As menu is open and set to save to the Downloads folder.
A Save dialog window will open.
The device's Save As menu is open and set to save to the Downloads folder. The project's name in the menu is highlighted to indicate that it can be changed, and in this example it has been changed to Drive Forward.
Name your project by typing in your device's Save dialog window.
Notice the .v5python file extension after the file name. All VEXcode V5 Python files will have this file extension.
The device's Save As menu is open and the Downloads folder is highlighted and set as the destination.
Select the destination, such as the Downloads folder.
The device's Save As menu is open and the Save button is highlighted.
Then select ‘Save.’
Previously saved VEXcode V5 Python project is visible from the device's files.
The file will save to the chosen destination on your device. All VEXcode V5 Python projects are recognizable by their .v5python extension.
VEXcode V5 Toolbar with the project name field highlighted and changed to Drive Forward.
The updated project name will be visible in the project name window.
VEXcode V5 Toolbar with the project name field changed to Drive Project. The label to the right is highlighted and reads Saved.
Once a project is saved, VEXcode V5 will automatically save all changes in a project.
Note: Whenever there is an unsaved project VEXcode V5 will prompt users to save their work if the user attempts to:
  • Close VEXcode V5
  • Create a new project
  • Open another project
Using ‘Save As’
VEXcode V5 Toolbar with the File menu open and the Save As option highlighted. Save As is the seventh option in the menu, below New Blocks Project, New Text Project, Open, Open Recent, Open Examples, and Save.
You can also use the ‘Save As’ option from the File menu to make a copy of a project under a different name or in a different location.
