Using the Autocomplete Feature in a VEXcode VR Python Project
Using the Autocomplete functionality while creating a Python project in VEXcode VR can help save time and prevent errors while typing commands.
How to Use Autocomplete
Step 1: Begin typing to open the selection menu.
VEXcode VR start menu with options to create a new project or open tutorials
The device or command name will appear in a drop-down selection menu.
Autocomplete menu showing Python command suggestions in VEXcode VR
To access a list of the possible commands available using the Autocomplete function, press Control + Space (on Windows, macOS, and Chrome OS).
Step 2: Make a Selection with the AutoComplete
Python autocomplete suggestions for a VEXcode VR project
Press “Enter/Return” or “Tab” on your keyboard or left click on the command with your mouse to make a selection.
Note that with longer selection menus, you can make a selection using one of the following options:
  • Use your “Up” and “Down” keys to select the name you want, then press “Tab” or (Enter/Return) on your keyboard to make the selection.
  • Use your mouse to scroll up and down in the Autocomplete menu. Then left click on the desired selection.
Step 3: Add a Dot Operator to List all the Commands Available to that Device
Autocomplete menu shows available Python methods after typing a period in VEXcode VR
Adding a dot operator (a period, “.”) will open a new menu of all commands available to the device.
Step 4: Make a Selection by Using One of the Following Options
Autocomplete menu showing available Python commands in VEXcode VR
  • Use the “Up” and “Down” buttons on your keyboard to navigate the menu and then press “Return" on Mac, “Enter" on Windows or Chromebook to make a selection.
  • Left click with your mouse on the desired command.
Step 5: Add Parameters
Autocomplete suggestions for Python commands in VEXcode VR
Parameters are the options that are passed to the command between the parenthesis.
Some commands require multiple parameters be set. Add a comma after a parameter to add another parameter.
Python autocomplete suggestions for a command in VEXcode VR
Once all parameters have been added to the command, the command is complete!
