Robot Brain Performance - V5 System Architecture
Powerful processors, combined with the VEXos operating system, allows V5 to tap into the next generation of educational robotics.
Robot Brain
V5 uses a new technology we call “Centralized Intelligence”, which provides the user processor with all sensor information. All Smart Sensors have their own processor, which allows them to simultaneously collect and process data as fast as possible. New information is instantaneously sent to the user processor’s high speed local RAM without interrupting the processor. Each time a line of code calls for sensor data as a user’s program runs, such as motor position, the most recent calculation is instantly accessed from memory.
“The user processor essentially knows all sensor data instantaneously.”
Sensor data communication to the Brain uses RS-485 - much like CAN without the overhead - which is immune to noise. Each sensor is the manager controller for its own 1.5 Mbps bus, which means it controls when and how often data is sent to the Brain.
The V5 Robot Brain has 21 Smart Ports available. Each of these are equipped with a digital circuit breaker, called an eFuse, that allow for short circuit protection without limiting motor performance. These eFuses allowed us to eliminate the PTC devices in the brain and motors that limited performance in the Cortex system.
Brain Programming
Events
when( STARTED )
when( Brain.LCD.PRESSED )
Settings
Brain.Screen.setCursor()
Brain.Screen.setFont()
Brain.Screen.setPenColor()
Brain.Screen.setPenWidth()
Brain.resetTimer()
Actions
Brain.Screen.print()
Brain.Screen.clearScreen()
Brain.Screen.clearLine()
Brain.Screen.newLine()
Brain.Screen.drawPixel()
Brain.Screen.drawLine()
Brain.Screen.drawRect()
Brain.Screen.drawCircle()
Sensing
Battery.batteryLevel()
Battery.temperature()
Brain.Screen.pressingX()
Brain.Screen.pressingY()
Brain.timer()
  V5 Robot Brain Specifications Cortex Microcontroller
Motor Ports Use any of the 21 Smart Ports 10
Smart Sensor Ports Use any of the 21 Smart Ports
Radio Ports Use any of the 21 Smart Ports
Tether Ports Use any of the 21 Smart Ports remove radios, use USB cable
Digital Ports Use any of the 8 built-in 3-Wire Ports 12
Analog Ports Use any of the 8 built-in 3-Wire Ports 8
3-Wire Expansion Add 8 more ports using a 3-Wire Expander.
The 3-Wire Expander uses one Smart Port.
VEXos Processor One Cortex A9 at 667 MHz
Two Cortex M0 at 32 MHz each
One FPGA1
ARM7
User Processor One Cortex A9
1333 Million Instructions per second (MIPS)
Cortex M3
90 MIPS
Ram 128 MBytes 0.0625 MBytes
Flash 32 MBytes 0.375 MBytes
User Program Slots 8 1
USB 2.0 High Speed (480 Mbit/s) Full Speed (12 Mbit/s)
Color Touch Screen 4.25”, 480 x 272 pixels, 65k colors
Expansion microSD up to 16 GB, FAT32 format
Wireless VEXnet 3 and Bluetooth 4.2 VEXnet 2
System Voltage 12.8 V 7.2 V
Size 4.0” W x 5.5” H x 1.3” D 4.5” W x 3.9” H x 1.0” D
Weight 0.63 lbs (285g) 0.30 lbs (137g)
1. A Field-programmable gate array (FPGA) is an electronic component used to build reconfigurable digital circuits. The V5 Brain uses the FPGA for touch screen inputs, screen layering, 60 Hz screen refreshing, timers, and the 21 smart ports.
