Using the V5 Robot Brain User Interface
V5 Robot Brain - User Interface
Simple touchscreen user interfaces are familiar to almost everyone, making V5 more approachable. The V5 Robot Brain features a 4.25” full color touch screen with 480 x 272 pixels.
V5 Brain powered on, with the screen showing the Home menu.
User interface features include the following:
  • Select and run one of 8 user programs
  • Run built-in VEX programs
  • Accessing program wiring lists
  • Accessing program controls
  • Run practice matches
  • Change languages
  • Select themes and backlighting
  • Screen rotation, and much more...
V5 Brain screen with a user project running. The screen shows a colorful geometric pattern drawn on a checkered background to indicate the range of graphics that users can create.
Programmers can also make use of the touch screen with the ability to draw pixels, lines, rectangles and circles, along with line color, width, and fill control. Multi-sized, multilingual fonts in any color are built in. User programs draw fast and efficiently on dual buffered internal memory, and the FPGA handles screen refresh at an incredible 60 Hz.
Flexibility can be found in every aspect of the V5 Robot Brain:
  • Smart motors
  • Smart sensors
  • Analog sensors
  • Digital sensors
  • microSD Card expansion
  • On-board diagnostics
  • Device wiring lists
  • Controller maps
  • Automatic wiring check
  • Automatic device firmware updates
Two V5 Brain screenshots are shown side by side to demonstrate the range of dashboard menus available. The Device Info and Smart Motor menus are shown as examples.
Dashboards are one of the most notable V5 advancements. There is a built in dashboard for every connected sensor and device, from switches and potentiometers all the way up to motors and the battery. Dashboards provide an incredible teaching and diagnostic capability, allowing you to see in real time what the sensor is actually doing, and what the data for that action looks like.
