Color & Part Number Info for VEX IQ
Many VEX IQ elements are now available in different colors. These colors will allow you to customize the look of your robot and add your own personal style. The purpose of this page is to serve as a reference for these VEX IQ color Identifiers, and to clarify part number information.
The first three digits of all VEX product SKU's refer to their respective product line. In the case of VEX IQ, the first three digits of all parts will be 228. The next four digits represent the product's color identifier, which can be referenced in the chart below. The final three digits of the SKU serve as the unique product identifier. This part of the SKU will stay the same for each unique product regardless of color (for example, a 2x6 beam will still be a 2x6 beam), but the unique center SKU will change depending on the color.
Part Color Color Name Color SKU ID RGB
Dark Grey 2x6 Beam. Dark Grey 3616 84, 88, 90
Red 2x6 Beam. Red 3445 210, 38, 48
Orange 2x6 Beam. Orange 3446 255, 103, 31
Yellow 2x6 Beam. Yellow 3449 255, 205, 0
Green 2x6 Beam. Green 3450 0, 150, 57
Blue 2x6 Beam. Blue 3196 0, 119, 200
Purple 2x6 Beam. Purple 3448 95, 37, 159
Pink 2x6 Beam. Pink 3451 229, 109, 177
White 2x6 Beam. White 3943 217, 217, 214
Medium Grey 64mm Wheel Hub piece with text next to it that reads Only used on Wheel Hubs, Idler Pins, and Universal Joints. Medium Grey 3944 137, 141, 141
Jet Black 2x6 Beam. Jet Black 3201 37, 40, 42
VEX IQ Part Number Information
Every element in the VEX IQ system has a unique part number. Assembled items or complete kits use a 7-digit part number, while individual parts use a 10-digit (or possibly 11-digit) part number.
For example, the VEX IQ Super Kit is a complete kit, so it has a 7-digit part number of 228-3060. Similarly, the Robot Brain is a standalone assembled item, so it has its own part number: 228-2540.
However, the Dark Grey 2x6 beam (for example) has a 10-digit part number (228-3616-021) since it is never sold individually. This 10-digit number is broken up into three groups:
  • 228, the VEX product line identifier - all VEX IQ products begin with 228
  • 3616, the 4-digit color-identifying number* - see the table above for each color's specific number
  • 021, the unique ID for that specific element - this is what differentiates 2x6 beam from a 2x8 beam
Note: For cases where a color doesn't matter (such as CAD files), 2500 can be used as the 4-digit color identifier. For example, a colorless 2x6 Beam would be 228-2500-021.
Diagram of two 2x6 Beam pieces side by side to compare their Part Numbers. The first is Dark Grey and the number reads 228, 3616, 021. The second is Blue and the number reads 228, 3196, 021. The three digit groups are described as the VEX Product Line Identifier, the VEX SKU Identifier, and the VEX Unique part Identifier. A note below the Unique Part number reads This group may be more than three digits long.
