Accessing Help in a VEXcode VR Python Project
Help explains what a command does so that you can figure out if it’s helpful for your project.
Accessing Help from the Tool Box
Help button that opens Python command help in VEXcode VR
Select the Help icon on any command in the Tool Box.
Help pane showing available Python commands for the selected item in a VEXcode VR project
You will see a screen extend from the right with information on the command selected.
Help button for opening project help in VEXcode VR Python
Select any commands that you want to learn more about.
Close Help option in the VEXcode VR Python Help panel
Hide the Help window when finished by selecting the right arrow next to the Help icon.
Accessing Help from the Workspace
Help button that opens Python command documentation in VEXcode VR
Right click or long press on any command in the Workspace.
VEXcode VR Help panel showing Python commands with descriptions and examples
A context menu will appear. Select “Command Help.”
Help pane showing Python command categories and context-specific command information
Help pane in a VEXcode VR Python project with the Close button highlighted
