Using the Distance Sensor in VEXcode VR
The Distance Sensor on the VR Robot reports the distance between the VR Robot and the nearest object. The sensor calculates distance by using the time it takes for laser light to bounce off of an object and return to the sensor.
Distance Sensor detects objects in front of the VR Robot and reports the distance in millimeters
The Distance Sensor is a sensor that reports the distance between the VR Robot and the nearest solid object.
Distance Sensor monitor displaying distance values while a VEXcode VR project reports the readings with blocks
The Distance Sensor uses the same principles as sonar devices to measure sound. It sends out a tiny pulse of laser light with its emitter at one side of the sensor, and then times how long it takes for the light to reflect back to the receiver at the other side of the sensor. The sensor calculates the distance based on how long the pulse took to make the round trip. Then, the Distance Sensor reports to the VR Robot how far the nearest object is.
Distance Sensor location on the front bumper of the VEXcode VR robot
The width of the Distance Sensors range of vision changes as it looks further away from the front of the VR Robot:
  • The sensor can detect objects within a 10 degree field of view when looking for objects less than 1000 millimeters (~ 39 inches) away.
  • The sensor can detect objects within a 5 degree field of view when looking for objects between 1000 millimeters (~ 39 inches) and 2000 millimeters (~ 78 inches) away.
  • The sensor can detect objects within a 2 degree field of view when looking for objects greater than 2000 millimeters (~ 78 inches) away.
Common Uses of the Distance Sensor
Distance Sensor location on the VR Robot and the direction it detects objects
The Distance Sensor can detect if there is an object in front of the VR Robot. This can be used to avoid an obstacle.
Using the Distance Sensor with VEXcode VR Blocks
Location of the Distance Sensor on the front of the VEXcode VR robot
The blocks used with the Distance Sensor can be found in the Sensing category.
<Distance found object> Block
Front distance sensor location on the VEXcode VR robot
The Distance Sensor detects if there is an object in front of it using the <Distance found object> block. The Distance Sensor can detect an object or surface within 3000 mm (~118 inches) of the sensor.
The <Distance found object> block is a Boolean block that returns a condition as either true or false and fits inside any blocks with hexagonal (six-sided) spaces for other blocks.
For more information on boolean blocks, view this article.
Diagram of the VEXcode VR robot showing the Distance Sensor and other labeled components
The value of the <Distance found object> block is a Boolean block that reports true when the Distance Sensor is close to an object, and reports false when it is not close enough to an object.
True or false will be reported and appear in the Monitor Console.
To learn more about the Monitor Console, view this article.
(Distance from) Block
Front-mounted Distance Sensor on the VR Robot detects nearby objects
Using the (Distance from) block, the Distance Sensor can report the distance of the nearest object in millimeters (mm) or inches.
Distance Sensor reading the object ahead of the VR robot in the Playground
The (Distance from)  block reports number values and fits inside any blocks with oval spaces.
For more information on reporter blocks, view this article.
VEXcode VR robot showing the Distance Sensor location and other main components
The value of the (Distance from) block in the units of millimeters (mm) or inches can be displayed on the Monitor Console in VEXcode VR.
Using the Distance Sensor in VEXcode VR Python
To begin programming the Distance Sensor with Python, you will need to first open a text project VEXcode VR. For more information, see this article.
Distance Sensor location on the front of the VEXcode VR robot
Next, locate the Sensing category in the Toolbox and find found_object and get_distance commands. These are functions that report a Boolean value or numerical value about the sensor.
Distance Sensor location on the VR Robot and its forward detection direction
To add the command to your project, you can drag the command in from the Toolbox, or type out the command in the workspace using the Autocomplete function.
To learn more about Autocomplete in VEXcode VR with Python, see this article.
