Starting and stopping a project in VEXcode VR will control when your VR Robot moves in its virtual Playground.
The following article will cover:
- How to Start a Project
- From the Toolbar
- From the Playground Window
- How to Stop a Project
- From the Toolbar
- How to Start a Project Again
- From where you left off
- From the beginning
From the Toolbar
To start a project, select the “Start” button. The Playground window will open automatically if it is not already open.
Once the “Start” button is pressed, the project will run and the VR Robot will perform the programmed actions in the Playground. The “Start” button will remain grayed out while the project is running. The project must be stopped before it can be run again.
To start a project from the Playground window, first ensure that the Playground window is open. To open the Playground window, select the Playground button in the Toolbar.
Then, select the Start button. Once the Start button is pressed, the project will run and the VR Robot will perform the programmed actions in the Playground.
The Start button will be replaced with the Stop button while the project is running. The project must be stopped before it can be run again.
From the Toolbar
To stop a project from the Toolbar, select the “Stop” button.
To stop a project from the Playground Window, select the Stop button.
You can also stop the project by pressing the "Reset" button inside of the Playground window.
Notice that the "Start" button will return to white once the project has been stopped.
The Start button will also return in the Playground window.
To continue running your robot from where it last left off, use the “Start” button again from the Toolbar, while leaving the Playground window open.
Or, use the Start button again from the Playground window.
From the beginning
To start your robot back at the beginning, select the “Reset” button in the Playground window or “Close” the Playground window.
