Starting and Stopping a Blocks Project in VEXcode VR
Starting and stopping a project in VEXcode VR will control when your VR Robot moves in its virtual Playground.
How to Start a Project
From the Toolbar
Start block used to begin a VEXcode VR project
To start a project, select the “Start” button. The Playground window will open automatically if it is not already open.
Start button in VEXcode VR to run a Blocks project
Once the “Start” button is pressed, the project will run and the VR Robot will perform the programmed actions in the Playground. The “Start” button will remain grayed out while the project is running. The project must be stopped before it can be run again.
From the Playground Window
VEXcode VR toolbar buttons to start, stop, or step through a Blocks project
To start a project from the Playground window, first ensure that the Playground window is open. To open the Playground window, select the Playground button in the Toolbar.
Then, select the Start button. Once the Start button is pressed, the project will run and the VR Robot will perform the programmed actions in the Playground.
Stop button in VEXcode VR to end a running Blocks project
The Start button will be replaced with the Stop button while the project is running. The project must be stopped before it can be run again.
How to Stop a Project
From the Toolbar
Stop button to end a running project in VEXcode VR
To stop a project from the Toolbar, select the “Stop” button.
Stop button in VEXcode VR to end a running project
To stop a project from the Playground Window, select the Stop button.
Stop and Reset buttons in VEXcode VR to stop the project and return the robot to its starting position
You can also stop the project by pressing the "Reset" button inside of the Playground window.
Start block begins the VEXcode VR Blocks project
Notice that the "Start" button will return to white once the project has been stopped.
Start button to run the Blocks project in VEXcode VR
The Start button will also return in the Playground window.
How to Start a Project Again
From where you left off
Start button in the Blocks toolbar runs the VEXcode VR project
To continue running your robot from where it last left off, use the “Start” button again from the Toolbar, while leaving the Playground window open.
Start button in VEXcode VR Blocks to run a project
Or, use the Start button again from the Playground window.
From the beginning
Reset button stops the project and returns the VR Robot to its starting position
To start your robot back at the beginning, select the “Reset” button in the Playground window or “Close” the Playground window.
