Using Comments in VEXcode VR with Blocks
Comments are usually added to projects to explain what a programmer wanted parts of the program to do. So they are helpful when collaborating and troubleshooting.
Drag a “comment” block and attach it to any block in a stack.
Comment attached to a block in the VEXcode VR workspace
Type any text, numbers, or symbols into the “comment” block.
Editing a comment in the VEXcode VR Blocks workspace
When you finish the comment, click anywhere outside of the comment or press the “Enter” or “Return” key to finish editing the comment.
Comment block added to a VEXcode VR block stack
Note: The inside of the comment block will turn from white to gray when finished.
