Create a Project - Project Help - VR Blocks
A new project opens any time you start VEXcode VR, but you can also open a new project after VEXcode VR has already started.
The following article will cover:
  • Create a project after launching VEXcode VR
  • Create a New Blocks Project after VEXcode VR has started
Once you launch VEXcode VR from vr.vex.com, you can begin creating your project.
Launch VEXcode VR
To create a new project after VEXcode VR has already started, open the File menu and select “New Blocks Project.”
Open a new blocks project
Note: When starting a new project, a prompt will appear asking to save if the current project has not been saved yet.
