Accessing Help in a VEXcode VR Blocks Project
Help menu in VEXcode VR Blocks opened from the question mark button
Help explains what a block does so that you can figure out if it’s helpful for your project.
Select the Help icon. It’s at the top right of the interface and has a question mark in it.
Help panel showing block descriptions and usage instructions in VEXcode VR
You will see a blank screen extend from the right until you select a block to learn about.
Help panel showing block descriptions and coding guidance in VEXcode VR Blocks
Select any blocks that you want to learn more about.
Close Help button in the VEXcode VR Help panel
Hide the Help menu when finished by pressing the right arrow next to the Help icon.
