Delete a Block - Tutorials - VR Blocks
Blocks in VEXcode VR can be deleted in a number of ways:
  • Drag to Delete
  • Delete a Single Block from a Stack
  • Delete All Blocks
Drag to Delete
Select a block or a stack of blocks in the programming area and drag them left to the toolbox to delete from your project.
Drag to delete a block
To remove a single block from a stack, context-select (right click or long press) a block in a stack and then choose “Delete Block(s)” from the context menu. This will also delete any nested blocks if a block with parameters is chosen to be deleted.
Delete a single block
Delete All Blocks
To remove all of the blocks in the programming area, context-select (right click or long press) the background of the programming area and choose “Delete X Blocks.” When choosing to delete more than one block, you will be asked to confirm removing all blocks to prevent accidental deletion.
Delete all blocks
Note: Choosing this option will not delete the “when started” block.
