Make Process Closed with Exit Code 2 - VEXcode V5 Pro
Make process closed with exit code 2 is generally a compilation/build error. The following article will cover:
  • How to troubleshoot the make error 2
  • Information from the Output
How to troubleshoot the make error 2:
  • Whenever you see the make process closed with exit code 2 error you can read the log in the output to see where the error is within your program. The Output can provide information on the following:
    • What row/column the error is in within the file
    • What the cause of the error is
Information from the Output:
In the following example, the output is providing the information that there is an error on line (row) 20 column 30. This is shown as, “20:30.”
The output also provides information as to why the error is shown. A semicolon is missing after the expression, “Brain.Screen.print(“Hello”)”
Note: If you are running an older version of the VEXcode Pro V5 application, previous versions of VEXcode Pro V5 were allowing special characters in the filename or the project name.
